  1. If you have a divx file that is 480 x 360 is it worth it to change the framerate to say 720 x 480 or will I see the difference? I understand that are standard frame rates for dvd and svcd but I was just wondering about quality.
  2. Member ZippyP.'s Avatar
    Nov 2002
    Lotus Land
    I think you're talking about resolution, frame rate is frames per second. Any time you convert from a lower resolution to a higher one the result is never good. You can't create pixels where there was none, it's best not to try.
  3. You're right, I meant resolution, my bad. So I guess that would mean that anytime you convert an avi that wasn't encoded at 480x480 for svcd or 720x480 for dvd, you will suffer a quality loss? Or am I missing something?
  4. Member ZippyP.'s Avatar
    Nov 2002
    Lotus Land
    Converting down is OK, it's going up that's no good for quality. Low resolution sux. So for people capturing, it's best to use a resolution equal or higher than what the final resolution will be.
    Also, 352 x 480 (called 1/2 DVD or CVD) is a legal DVD resolution and plays in many players when authored as an SVCD. It's good to use now if using CD's as it allows for simple conversion to DVD later.
