i jus dl'd a movie from OVERNET that is a "bin" file. i was jus wonderin how do i watch it b/c i tried it in windows media player, radlight and it doesn't open? help...
devil may cry
The "CUE/BIN" image is a disc image. It isn't a video file. You are meant to burn it to a disc.
If you want to be able to browse the contents of the disc image, I suggest that you get Daemon Tools and mount the image as a virtual CD.
https://www.videohelp.com/tools
Regards.Michael Tam
w: Morsels of Evidence -
Are you suppose to burn them as VCD or data(Iso) mode in order to watch the movie.The "CUE/BIN" image is a disc image. It isn't a video file. You are meant to burn it to a disc.
You can burn CUE/BIN images with CDRDAO (VCDEasy) / CDRWin and Nero.
With Nero, select "burn image" and select the CUE file.
If you only have the bin file but not the cue file, then you can regenerate the cue file by using the CUE/BIN regenerator function in GNU VCDImager Tools GUI.
Regards.Michael Tam
ok thank you for all your help I figure out the problem. I'm continuing to make VCDs
cue and bin files
By natty in forum Newbie / General discussionsReplies: 2Last Post: 21st Jun 2011, 16:25 -
extracting the bin/cue from .oo1,.002 etc files
By belwas in forum Newbie / General discussionsReplies: 5Last Post: 7th Jan 2010, 01:59 -
Having trouble with .bin/.cue files
By UncleBose in forum Software PlayingReplies: 8Last Post: 12th Jan 2008, 07:06 -
The FilmMachine Xvid to SVCD conversion not creating Bin/Cue files
By louv68 in forum Video ConversionReplies: 2Last Post: 24th Jul 2007, 10:11 -
What files/settings do I need for bin/cue
By Choppa in forum Authoring (VCD/SVCD)Replies: 9Last Post: 23rd Jun 2007, 22:29
