Hi,
On your SCVD link: http://www.dvdhelp.com/svcd there is a pointer to "VCD Header Trick" and goes off to this link: http://www.geocities/com/evbq64a/index.htm
The idea is that if your standalone player only supports VCD, you can make a SVCD work by doing some minor edits using TMPGEnc. I tried it and did not work:
Here were my steps:
1) Convert by SVCD bin/cue files to MPEG-2 - Using VCDGear
(I use DVD2SVCD for my DVD backup and I only save the bin/cue files
and delete the rest. Disk Space issues..)
2) Bring the MPEG-2 to TMPGEnc and use the 'Simple multiplexing with MPEG-1 - See the above link for details
3) Convert the new MPEG-1 file to bin/cue - Using VCDGear
4) Burn using Nero
I did all that and tried to run this on the stand alone DVD player(which only supports VCD). It did not work.
Question:
1) Has anyone tried this scheme ? If yes, Did it work and how ?
I have two DVD players(JVC), one supports SVCD and the other doesn't. I just wanted to do 'some tricks' to the VCD supported player to make it work with a SVCD disk.
Thanks in advance for any suggestions.
shuq
Well, as you've found, the Header Trick just does not work on all VCD capable players. You didn't say the brand of your player, but Sony players frequently can play them. I'm afraid your SOL.
"Art is making something out of nothing and selling it." - Frank Zappa -
My standalone player is JVC XV-421 . This is the one where the 'Header Trick' is not working.
shuq
Make subtitles work with media player classic
By arnie22112000 in forum SubtitleReplies: 27Last Post: 6th Sep 2013, 21:00 -
How to make subtitles work in a SBS 3d on my blue ray player?
By megatron031 in forum SubtitleReplies: 1Last Post: 25th Sep 2011, 01:25 -
Make MKV encoded with AVC Playable with Standalone DivX Player
By adalect in forum Video ConversionReplies: 2Last Post: 2nd Jun 2009, 23:42 -
how can i make sure my dvd will work in any player?
By el_nex in forum Newbie / General discussionsReplies: 6Last Post: 6th May 2009, 18:22 -
subpictures work on powerdvd but not standalone player
By domhnall in forum DVD RippingReplies: 6Last Post: 19th Aug 2007, 08:12
