Hi,
Just wondered why I can`t capture Video and surf the internet at the same time..........can`t see any possible conflicts.
It keeps saying device in use when I try to use both the modem and the capture card. I have even tried swapping PCI slots.
Thanks,
Jez 8)
What about sharing IRQ ?
Pinnacle Studio 8 and DV home video editing (ver.9 already home) -
Thanks for your quick reply donpedro.
I have looked in Control Panel / System (I am using XP) but I cannot see any IRQ conflicts....strange huh...
Someone mentioned in a previous post about disabling my Firewire port....I did try it but that didn`t work either.
Any further advice?
Regards,
Jez 8) -
I am just shooting blindly.... but did you check in device manager option "Resources by connection" ? (use View menu)
I tried a few other things, but still no luck............
Has anyone else encountered this sort of problem?
Regards,
Jez 8)
computer will not boot with old modem card removed??
By cal_tony in forum ComputerReplies: 15Last Post: 16th Mar 2010, 11:58 -
Capture card or Video card w/ capture tool
By joelson in forum Newbie / General discussionsReplies: 1Last Post: 11th May 2009, 11:45 -
What software is best to use for recording TV with a PCTV Pinnacle card?
By MJBoa in forum Capturing and VCRReplies: 1Last Post: 31st Jan 2008, 20:18 -
PCTV Rave Card - trouble capturing xbox + tv audio
By chocolate_brownie in forum Capturing and VCRReplies: 2Last Post: 24th Jul 2007, 09:38 -
Using Capture/Recoding PCI card - GV-650 Video Capture Card
By Confused Chimp in forum Capturing and VCRReplies: 1Last Post: 6th May 2007, 18:15
