is there a safe way to make sure you get a great vcd on one try, i mean, i check for bad frames with vdub, then it tels me that i have no bad frames, then i encode and all that other stuff, but when ive finished encdoding these last few times, ive gotten two bad discs that stop good ways through the flick, should i check the file after its encoded, but if the source file is good, shouldn't the encoded one be just as good.......id like some advice from yall, i have all my codecs, and i ahven't installed any software lately...so i dont see the problem..holla back
Results 1 to 1 of 1
Premiere CS3 exporting bad frames
By spicediver10191 in forum EditingReplies: 4Last Post: 17th Apr 2012, 17:39 -
VirtualDub - fixing bad frames with blending and without re-encoding
By spicediver10191 in forum Video ConversionReplies: 3Last Post: 11th Apr 2012, 08:15 -
How to ensure some frames are in correct aspect ratio?
By ANOther1676 in forum EditingReplies: 1Last Post: 30th Apr 2011, 22:16 -
fixing bad frames
By vidclip in forum Newbie / General discussionsReplies: 2Last Post: 10th Jan 2010, 15:00 -
Cutting bad frames with VirtualDubMod
By lazaruz in forum EditingReplies: 2Last Post: 18th Sep 2007, 03:39
