I installed the sourceforge drivers on my system in order to fix some issues with AVI_IO. They fixed them but introduced other issues. Has anyone had a problem with after installing the drivers, the hue/contrast/brightness/saturation settings changing and the defaults not working correctly. All the settings were suddenly way off after installation. Changing to the defaults made the video too dark. I can get close but it still does not really look right and each channel seems to be different. Any had this happen or have any ideas/suggestions? I am using a Pinnacle PCTV card which is on the approved list. I did not have this problem before the installation.
The FAQ of the btwin site seems to indicate a problem with this. Is anyone else having this issue and if so, what settings for hue, saturation, brightness and contrast are you using to get good video?
Excellent guide to tweaking virtualdub for capture which demonstrates priniciples that can be applied to other cap programs
http://arstechnica.com/guide/audio-visual/videocapturing/vidcap-5.html
Software that adjusts color and brightness of video
By ericdunn in forum Newbie / General discussionsReplies: 5Last Post: 24th May 2010, 06:48 -
Need Editor for Contrast, Brightness, Color Saturation
By HorseTears in forum EditingReplies: 1Last Post: 15th Dec 2009, 10:32 -
Gamebridge color / brightness setting help
By FakeFx in forum Capturing and VCRReplies: 0Last Post: 16th Feb 2008, 01:45 -
Change brightness, contrast, color, etc.
By JoeMuskie in forum EditingReplies: 4Last Post: 22nd Oct 2007, 22:26
