  1. I was trying to convert a file xvid.avi with TMPGENC to burn later as a Svcd but TMPGENC came up with an error"Runtime error 216 at 00002f3c" help please!?????
  2. straight from the search feature up ^^^^ there and typed in runtime+error ... first page says
    If TMPGEnc says that the video time / runtime is way too long
    Try change the directshow reader priority, in TMPGEnc under Option->Environmental settings->VFAPI plug-in and right click on the DirectShow Multimedia File Reader and increase the priority to 1 or 2 or to the top of plugin-list and reopen the video. If that doesn't help you can always use the source range to select exact what to encode, under Settings->Advanced in tmpgenc.
    if that dont work then you can try
    http://www.google.com/search?s=main&as_q=Runtime%2Berror+&SUBMIT=Search&domains=www.dv...p.com&safe=off
  3. Member ZippyP.'s Avatar
    Nov 2002
    Lotus Land
    Man, that search feature is somethin' else!
  4. Originally Posted by ZippyP.
    hehehe
