I just installed win 2000 and can't seem to use avisynth to do an IVTC in conjunction with TMPEG. I changed the paths to match the new partitions but I'm getting a message that the avisource can't open the file. Everything was working fine in Win XP so all I should have had to do was change the paths. Any ideas?
Either your path is incorrect, or your using something like DVD2AVI project files, with a newer version of DVD2AVI. AVISynth has a problem with versions of DVD2AVI higher than 1.76.
Paste your script into the forum, and let us know what line number you had a problem with. Also paste the specific error message.Impossible to see the future is. The Dark Side clouds everything...
Internet Explorer 6 problem on Windows 2000
By edong in forum ComputerReplies: 17Last Post: 23rd May 2008, 00:04 -
Windows 2000 Questions
By dafoe in forum ComputerReplies: 2Last Post: 21st Dec 2007, 16:31 -
Windows 2000 Hotfix
By MarioB in forum ComputerReplies: 13Last Post: 18th Jun 2007, 13:39 -
Windows 2000 options, if any.
By AlecWest in forum Capturing and VCRReplies: 6Last Post: 18th Jun 2007, 00:22 -
Windows 2000 question.
By AlecWest in forum ComputerReplies: 34Last Post: 1st Jun 2007, 17:54
