Hi
You know the problem ,
You download a movie from the net but its in Avi format, but if i burn that with Nero it wont go on 1 disc so i have to put it on 2 disc on convert it to Mpeg 1 with the help of tmpgce, But i want to put it on 1 CD But How ???????????
Cna anyone out there please help me ??
Thanks for trying even if you cant
Ron
you must lower the bitrate. but quality will suffer. use a bitrate calculator from the tools section.
i download a lot on movies from the net that are avi. i use tmpgenc 2 pass vbd svcd template long sustained format thats on teh wizard. there are better templates you can use but i am happy with with this. i normally put like 100 minutes on each cd. then you can burn with nero.
Thanks Ghoster , Is there any chance you could possibly go through the process a little so i can have a try at it ???
Thanks for any help you can give
Ron -
Cheers Treebeard ,
Can you give me an idea how to do that ?? Then i can have a go at it , I usually use the tmpge wizard to convert the files
Ron
DVD playback problem, possibly a file structure problem?
By snuhmcsnort in forum Newbie / General discussionsReplies: 8Last Post: 17th Aug 2010, 04:23 -
problem after problem - dvd architect, not enough room in temp files
By jgeck90 in forum Newbie / General discussionsReplies: 7Last Post: 1st Dec 2008, 03:35 -
HDD problem, gigabyte's easy tune major problem and etc....
By MidnightMike in forum ComputerReplies: 4Last Post: 28th Jul 2008, 21:57 -
video card problem causing watching movies problem?
By vipertongn in forum ComputerReplies: 3Last Post: 11th Jun 2008, 11:39 -
WinTV PVR 150 problem and Geforce 7600 GS problem
By deck in forum Capturing and VCRReplies: 5Last Post: 16th Jun 2007, 03:03
