I have finally got it down to the 2 cards above as to which one to use based on my budget for capturing analog sources. Can anyone tell me from personal experience how their capturing went with either card with analog sources like 8mm and vhs?
I would appreciate any feedback on this.
Thanks and regards,
RayBan
ATI 9600 Pro; Abit BH7; P4 2.4Ghz 533; 1G PC2700 DDR; Toshiba SD5002 DVDR; WD 120G 8MB 7200 Capture Drive & 160G 7200 Program Drive; Pinnacle Studio 9 and Nero6 -
If you are looking for realtime mpeg capture the AIW will do a nice job
(as nice as realtime encoding in the hobbyist pricerange can do) I own 2 older AIWs and a Avermedia Stereo TV card(and some others) By using the btwincap drivers with the avermedia and capturing to huffyuv you will get the best quality analog capture in the pricerange. The AtoD circuits of the BT8X8 are quite good and huffyuv is mathematically lossless. I believe the current drivers of the AIWs will support capturing to huffyuv but you may not be able to use MMC to do so. With the BT8X8 card you separate the display card from the capture card and have a group of open source developers continuing to polish the drivers for the capture card. With the AIW you are tied to ATI for drivers.
Once you have the capture you can convert to Mpeg 1, 2 or 4 in any method you choose.
ATI All In Wonder cards
By david151 in forum Capturing and VCRReplies: 19Last Post: 25th Apr 2012, 16:57 -
Unable to transfer some VHS to DVD using AverDVD EzMaker PCI Card
By fromvn in forum Newbie / General discussionsReplies: 4Last Post: 26th Oct 2008, 12:38 -
ATI AIW 128 720x480 mpeg captures have horizontal tearing
By cybertheque in forum Capturing and VCRReplies: 16Last Post: 17th Sep 2008, 21:53 -
Moving from analog capture card to digital. Focus on cards with DVB-C (US)?
By ColKurtz in forum Newbie / General discussionsReplies: 6Last Post: 19th Aug 2008, 22:25 -
Which of these TV-cards capture analog to AVI, using Huffyuv or M-JPEG,...
By dOdGE dIZ in forum Capturing and VCRReplies: 15Last Post: 9th Mar 2008, 09:01
