I have 2 mpeg2 (SVCD) files, which has all the same properties (frame rate, codec etc.)
These 2 files plays flawlessly on every mpeg2 player.
I tried to join these files into one file (mpeg2).
I have tried to use many software titles - TMPGenc, Easy Video Joiner and more. No matter what I did, I always have severe problem to work with the resulting file; It starts OK, but if I want to fast forward the movie, any software I use to play it always stucks.
I try to cut the resulting file, the result is bad.
Even in Windows media Player, the total time of the file, showing wrong information.
What can cause all these results?
Any help will be appreciated.
I had a similar problem with joining 2 mpegs. I used TMPGenc to join the to mpegs, and they were joined successfully. I then proceeded to author the dvd with DVDit. When attempting to create chapter points in the joined movie I would then get an error in DVDit "this file is not compatible with DVDit".
My workaround was to add the 2 movies to the dvd and add seperate chapter points in each movie.
Not the best solution, but I tried everything and could not get the joined file to work correctly.
2 things of interest
1. When joing MPEG2 files using TMPEGnc always make sure that you choose the MEPG-2 Super VideoCD(VBR) from the drop down list.
2. Try using M2Editpro or MyFlix XE as an alternative to to TMPEGnc, these are both excellent MPEG2 joining programmes with the only drawback that there both shareware so you are limted in what you can do.I Have Always Been Here
Toshiba Regza 37Z3030D, Toshiba HD XE1 + EP-10 ( Both Multiregioned), Samsung BD-P1500 Blu Ray. OPPO DV-983H
Problems joining multiple MPEG2 files together.
By MagicPockets in forum Newbie / General discussionsReplies: 3Last Post: 30th Jan 2010, 10:47 -
Simple MPEG2 Cutting/Joining Question
By thefiddler in forum EditingReplies: 4Last Post: 21st Dec 2009, 16:39 -
need joining of 2 mpeg2 files.
By snafubaby in forum EditingReplies: 3Last Post: 21st Dec 2008, 17:51 -
Joining Mpeg2 files from the command line
By roden in forum Newbie / General discussionsReplies: 3Last Post: 9th Oct 2007, 10:02 -
joining DVD mpeg2 files without re-rendering
By cheeseplease in forum EditingReplies: 4Last Post: 10th Aug 2007, 13:10
