Here is my problem. Authoring a DVD to PAL and NTSC. Captured it all up PAL and all worked fine. The trouble i have, is when i put it through scanners converter, using the PAL source and converting it to NTSC. The NTSC output is grainy and liney. Doesn't matter what bitrate/GOP i use the video remains the same. could it be a problem with the scanner converter or something else
-Bish0p
Firtst of all, what software are you using? Canopus Procoder is supposed to be the best software for NTSC<->PAL conversions (Allthough really slow, converting a NTSC DVD to PAL (100 mins) with "Mastering quality" settings took my old workhorse Duron 800 MHz incredibly 172 hours)
yeah sorry should've said, using a SD-500 from sonic, and converting it VIA a hardware box (MTSC EVO2)
-Bish0p
Frame rate conversion for NTSC to PAL conversion?
By Trellis in forum EditingReplies: 33Last Post: 27th Jul 2010, 09:55 -
NTSC video with a film-like/PAL to NTSC conversion type of look that shouldn't
By Bix in forum RestorationReplies: 34Last Post: 8th Feb 2010, 15:17 -
PAL to NTSC, NTSC to PAL framerate conversion?
By Baldrick in forum Video ConversionReplies: 44Last Post: 5th Dec 2009, 23:31 -
PAL to NTSC Conversion with DD
By cottage in forum Video ConversionReplies: 5Last Post: 16th Feb 2009, 16:10 -
NTSC to PAL, PAL to NTSC framerate conversion?
By Baldrick in forum Video ConversionReplies: 23Last Post: 23rd Apr 2008, 11:19
