I created the m2v and mpa files using Premiere 6.5's MPEG Exporter. Bring the m2v file into DVDMF2, video previews fine but no sound. OK, try Replace Audio, select the appropriate mpa file, error message says "No Audio Data". The same thing happens using the mpa files provided with DVDMF2 as background tracks.
The mpa file plays fine in Media Player, and if instead of producing two files, I export a multiplexed mpg file from Premiere, all is fine in Moviefactory.
Any ideas what is causing this? If not, is there any real difference in quality between using m2v+mpa or muxed mpg files?
Thanks in advance.
Results 1 to 1 of 1
Ulead Moviefactory 6 transition Help
By musickerns in forum Newbie / General discussionsReplies: 2Last Post: 18th Jun 2011, 13:26 -
Ulead Moviefactory
By acw in forum Newbie / General discussionsReplies: 10Last Post: 24th May 2009, 00:51 -
Ulead MovieFactory 6 Menu problems
By cheeseandcrackers in forum Authoring (DVD)Replies: 7Last Post: 18th Jan 2009, 00:59 -
Ulead DVD Moviefactory 5
By Flying Doctor in forum Authoring (DVD)Replies: 2Last Post: 2nd Aug 2007, 10:43 -
Questions about Ulead DVD MovieFactory 6
By cheeseandcrackers in forum Authoring (DVD)Replies: 5Last Post: 18th Jun 2007, 10:46
