Hi, I've got a divx movie but the audio is slightly out of sync. The fps is 23.976 and the audio is mpeg3 115kBit/s 48,000Hz stereo.
Ive got ulead video studio6 and cool edit pro2.
Is there anyway to fix the problem with these two programs. And is it better to fix it in divx format or mpeg format?
thanks.
the 115kbit tells me that the audio is VBR: Variable BitRate
How to fix that?
Open the file in Virtualdub (preferable, virtualdub 1.3c)
Audio: Conversion-> 44100Hz
16Bit
OK
Video: Direct Stream copy
File => SAVE WAV
Now, when that is done, you go to AUDIO -> WAV AUDIO
select the WAV you just made
File: SAVE AVI
and you should have a perfect movieWanne earn something a couple of dollars?
http://www.gold4email.com/signup.php?r=427
(^--no minimum pay-out!)
http://www.CashRoyal.com/cgi-bin/signup.cgi?r=sluarg1@hotmail.com -
so i cant use the programs i have?
If i use virtual how long will it take to convert the audio and the movie, and will the quality and file size be the same as the original or will it be larger?
thx.
Increasing Audio volume on AVI/DivX/Xvid with AC3 Audio
By Spacedementia87 in forum User guidesReplies: 21Last Post: 24th Dec 2021, 08:21 -
DivX audio Q
By Tafflad in forum Newbie / General discussionsReplies: 7Last Post: 25th Jul 2011, 13:13 -
No audio on divx file
By didikai in forum AudioReplies: 5Last Post: 30th May 2010, 10:33 -
Converting Divx w/ Vorbis audio to Divx w/ MP3
By tachyon2u in forum AudioReplies: 3Last Post: 24th Feb 2008, 00:35 -
no audio on some divx files
By philquad in forum AudioReplies: 6Last Post: 2nd Dec 2007, 00:16
