I have a movie, Super troopers which is a dvd rip .avi file and its 716 MB. Is there anyway to put it on a cd? I just want to be able to keep all my avi's on cds rather then on my hd, and would rather not convert them into a vcd or split them into 2 cd's. Thanks in advance. OH! Also, sometimes when I try to cut and paste some avi movies and delete some they wont let me, a error comes up saying a program is using it...however I dont have it open
If your burning program and your burner support overburn then it might fit, else try some of the oversize CD-r's (900Mb I think).
Let me guess you're running XP? Try this: https://www.videohelp.com/forum/userguides/100406.php
8)
"Art is making something out of nothing and selling it." - Frank Zappa -
You can try overburning. Nero can do it, not really sure of the exact options.
hey thanks man, the guide fixed my problem, I will have to check to see if it has overburn, thanks for all the help
you can cut off the credits at the end, and if that's not enough than you can reduce the audio bitrate, and if that's not enough than you can reduce the video bitrate. But remember that you will lose some of the audio and video quality if you are doing this. here is a guide that might help you as well:
https://www.videohelp.com/avi2divx.htm
How can I Burn DVD using avi file and .srt file as subtitle
By Gayanx in forum Authoring (DVD)Replies: 7Last Post: 15th Jul 2012, 01:56 -
Convert DVD to ca 700 MB avi using what?
By younso in forum DVD RippingReplies: 2Last Post: 9th Feb 2011, 18:57 -
making an avi file smaller to burn
By enigmatic620 in forum Newbie / General discussionsReplies: 2Last Post: 13th Feb 2009, 09:29 -
Would there be quality loss if 2 avi files of 700 mb made into one DVD
By meurglys0 in forum Authoring (DVD)Replies: 8Last Post: 11th Apr 2008, 21:57 -
HELP!!! Trying to burn .avi file, with subs, to DVD!
By BeatriceBlue in forum ffmpegX general discussionReplies: 6Last Post: 27th Feb 2008, 03:49
