Hi all,
Please correct me if I am wrong. The DVD movies that we buy or rent from stores are DVD-ROM and the blank DVDs that we use to back them up are DVD-R. So, does this mean that when we burn a DVD-R it becomes DVD-ROM? If this is correct, why all players are compatible with DVD-ROM but not all of them are compatible with DVD-R. Finally, If the DVD that we rent is totally something else, is there any burner that can burn that kind of DVDs. Thanks for your input.
Physically,
They're different (ROM=Aluminum/Silvery Layer stamped/molded and sandwiched in plastic vs R=Laser activated Dye sandwiched between plastic vs RW=Laser actived Polymorphic Crystal sandwiched between plastic)
Optically,
R and RW are made to be close to IDENTICAL to ROM.
Structurally,
The main sections are identical, but the Pre-User data sections are different (ROM vs -R(Authoring) vs -R(General)/-RW vs +R/+RW vs RAM).
Logically (file-system and media layout),
They are IDENTICAL (Unless you're talking about DVD-VR recording, etc). All use Mode1 Data, ISO9660/microUDF bridge format, with VIDEO_TS folder with IFO/BUP and VOB files.
No.So, does this mean that when we burn a DVD-R it becomes DVD-ROM?
No, they are pressed in a factory. Molded/stamped much like LP records or coins.If the DVD that we rent is totally something else, is there any burner that can burn that kind of DVDs.
CD-ROM vs. DVD-ROM
By Judson in forum MacReplies: 10Last Post: 6th Apr 2012, 08:33 -
mini DVD recorded by SONY DCR-DVD203 unreadable at DVD ROM of PC
By knightatarms in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 31st Dec 2010, 10:02 -
DVD Rom reads DVD but won't play DVD
By cougaris in forum DVD & Blu-ray PlayersReplies: 2Last Post: 27th Jul 2008, 21:58 -
question about difference between TMPGEnc DVD Author and DVD Flick
By jimdagys in forum Authoring (DVD)Replies: 1Last Post: 23rd Apr 2008, 20:06 -
VHS, Hi-8 transfer to DVD and DVD-ROM MPEG file online service?
By DeanPk in forum Newbie / General discussionsReplies: 1Last Post: 22nd Jan 2008, 14:30
