Hi All,
Still a newbie at all of this. I've read that alot of people who burn DVD-9's onto 2 seperate 4.7 DVD-R/RW's. Instead of using 2 DVD's, couldn't you just use one 9.4 GB DVD-R? Would you be able to use this type of media with DVDXCOPY? I've used DVD Encrypter, DVD2ONE & Nero Vision Express & a Toshiba 5002. Can you also burn this same method (DVD-9 to 9.4 GB DVD-R) using Nero Vision? Thanks for any info or insight!
I believe the 9.4 GB DVD-R are just two sided. So you would still have to get up and "flip" the disc. You would also have no where to label or write on the disc and you would have to be careful to not touch either side.
Not sure if that is worth it just to have one DVD instead of 2 if you want a perfect 1 to 1 copy.Use what works for you...
Need Help with Panasonic DVD-LS83 or DVD-LS86 8" Portable DVD Player!
By Big C in forum Portable VideoReplies: 3Last Post: 1st Aug 2011, 17:35 -
Samsung DVD-HR753 DVD and HDD recorder rejected all my blank DVD
By undangltn in forum DVD & Blu-ray RecordersReplies: 1Last Post: 14th Mar 2010, 12:34 -
CloneDvd2, Dvd Decrypter, Dvd Fab, Dvd Shrink? Help Choosing Software...
By frieday in forum DVD RippingReplies: 10Last Post: 5th Aug 2009, 08:14 -
DVD recorder LG DR175B won't read burned DVD but common DVD Player reads it
By Mycow in forum Newbie / General discussionsReplies: 0Last Post: 12th Aug 2007, 17:59 -
DVD+/-RDL Playback on Yamaha DVD-C750, DV-C6770, and DVD-C950
By Big C in forum DVD & Blu-ray PlayersReplies: 5Last Post: 11th Aug 2007, 08:59
