  1. I have captured the Vedio from SONY Digital Vedio Camcorder to a WMV file using Windows Movie Maker. I want to create VCD using that. Which is the software I need to use to convert the WMA file to MPEG-1 file.
    Apr 2002
    The State of Frustration
    Try using TMPGEnc. After loading, select Browse, then under file types, select Files of type. You should be able to find and select your video file and load it then.
    Hello.
