Im using the 2x -r's from www.O1ne.com on a dru500u with 2.0f
I've noticed the last 5 percent or so of my movies freeze on all my test dvd players. Is this a known issue with ritek g03 disks? + is there any way around it ?
Regards
I`ve got to say these are the only discs that I always use if I can locate them, so far I`ve had 300 of them and have had no returns from them and write perfect almost every time out of the ones I`ve used maybe 15 coastres but mainly my fault, I have the same drive as you and the same firmware, regards nipperlocko.
DVD playback problem, possibly a file structure problem?
By snuhmcsnort in forum Newbie / General discussionsReplies: 8Last Post: 17th Aug 2010, 04:23 -
Complex problem, extra some chpts from 2 dvd and combine into 1 dvd + menu
By Shihtzu88 in forum Authoring (DVD)Replies: 1Last Post: 23rd May 2009, 08:09 -
problem after problem - dvd architect, not enough room in temp files
By jgeck90 in forum Newbie / General discussionsReplies: 7Last Post: 1st Dec 2008, 03:35 -
Problem rendering DVD and menu with Ulead DVD Movie Factory 6
By Jeff_NJ in forum Authoring (DVD)Replies: 2Last Post: 12th Sep 2007, 03:26 -
Playing DVD burned slide show on DVD player problem
By zenfoos in forum Newbie / General discussionsReplies: 4Last Post: 29th Aug 2007, 21:37
