Hi,
I tried converting a .mov file (8 MB) in TMPEG into an .mpeg file. THe original file was rendered using a sorenson video 3 codec.THE output from TMPEG is 11Mb with a little(negligible) loss in quality.WHat could the reason be, for the increase in file size? Any suggestions on h ow to get a lossless output from TMPEG with the same or less file size as the original file?
Cheers,
HAVAN
Size changes b/c your changing file types and bitrate changes. to increase quality try multiple passes, w/ lower average bitrate. are you trying to make vcd or svcd? Quality will never be better than source though.
hey,
am trying to make VCD.BTW, wat is all this multiple pass about and how do i change the bitrate. That option is dehighlighted for me.Am not able to make any changes.AM not able to change even the resolution. WAt shud i do. Thanks for the effort.
Havan
PowerDirector makes final DVD files, size larger than mpg file's size, why?
By Xor2 in forum Authoring (DVD)Replies: 4Last Post: 22nd Dec 2011, 17:29 -
MB increases when making copy of video fie.
By MaddogX in forum Newbie / General discussionsReplies: 16Last Post: 12th Oct 2011, 12:15 -
File size differs from data size--HUH?!
By atoledo123 in forum MacReplies: 2Last Post: 9th Sep 2011, 13:19 -
Youtube increases time limit to 15 minutes.
By aedipuss in forum Latest Video NewsReplies: 30Last Post: 31st Jul 2010, 17:46 -
Question: MKV File Size vs MP4 File Size
By VideoNoobz in forum MacReplies: 6Last Post: 20th Feb 2010, 02:44
