I seached other topics on this forum dealing with that issue but I didn't find any answer...
So here's my problem: I've got a really good quality AVI file: about 670 MB for a 49 minutes movie. I wanted to burn it on DVD.
I did some research on dvdrhelp.com and on the internet to seek the best solution and it appears to be this one: creating two separate files, a m2v file for the video stream and a wav file (or mp2 if you want MPEG sound -- but I don't want it) for the audio stream, then remux the files with a DVD authoring software and burn the DVD. Well, it's not as simple as that.
Here's what I did: I extracted the audio stream from the AVI file using TMPGEnc, so now I've got a big WAV file (about 535 MB) compatible with DVD format. I then encoded the video using TMPGEnc again, and I've got a big m2v file (about 2.7 GB -- I wanted the best quality possible).
After that I tried to remux the files using MPEG Tools in TMPGEnc but obviously it doesn't accept WAV files as audio streams -- and I'd really like to keep the WAV quality, if that's possible.
I tried to do it using IFO Edit, with the "Authour new DVD" option. The multiplexing process went good and pretty quick (15-20 min. or something). When I tried to read the VOBs newly created, audio and video streams were TOTALLY out of sync, and it looked like the video skipped lots of frames without apparent reason. I checked the IFO files in IFO Edit and the video format is good (PAL, 25 fps), audio is ok as well.
Did anyone have the same problem? Did I do something wrong and how could I solve this problem??
Thank you very much in advance for your help.
PS: I checked IFO Edit forums and I did not find any answer either.
Before extracting the audio with virtualdub - have you made sure you have no bad frames?Originally Posted by Will Bailey
Yes I did: no bad frames have been reported in VirtualDub. The AVI file plays totally fine in Windows Media Player but the VOBs are just acting weird...
are you checking with mp3freeze version of virtualdub
the rest was edited because i don't read
Actually I didn't try with MPEG sound, because I wanted to keep the WAV quality.
Thanx for the suggestion, I'm gonna try multiplexing the m2v file with a mp2 file and see what comes out.
I think it kinda sucks that you can multiplex m2v + WAV files in TMPGEnc...obviously it's the same with IFO Edit...Maybe it only works with AC3?
PS: yes I checked with mp3freeze...
AVSTODVD avi to dvd audio sync problem
By stem300 in forum Authoring (DVD)Replies: 6Last Post: 26th Dec 2011, 14:52 -
An app to visually sync audio to video similar to Subtitle Edit visual sync
By cinesimon in forum AudioReplies: 3Last Post: 6th Sep 2011, 08:54 -
audio sync problem creating DVD from AVI files
By EtherJones in forum Authoring (DVD)Replies: 2Last Post: 8th Jun 2010, 11:12 -
MKV->DVD Audio/Video Sync Problem
By Maikeru-sama in forum Video ConversionReplies: 1Last Post: 16th Aug 2008, 19:32 -
Audio Sync Problem Joining 2 AVI's Together from a 2 DVD Set
By boofer in forum EditingReplies: 6Last Post: 22nd Jul 2007, 02:29
