what s the best format to capture video and what resolution if i want to make a dvd from it and what program to use to create the dvd?
uncompressed AVI at 720x480 resolution with scenarist.
realistic answer:
AVI with pegasus codec set at 18 at 640x480 resolution, using CCE to convert to 352x480 mpeg at 5000kbit 48mhz audio and using Movie Factory 2 to put on DVD.
Easycap Video Grabber Capture card USB 2.0 RCA and S-Video?
By ffxdean in forum Capturing and VCRReplies: 149Last Post: 16th Mar 2011, 01:02 -
Best video capture software? Is AVI better for capture? Is TV screen better
By johnharlin in forum Capturing and VCRReplies: 5Last Post: 21st Feb 2011, 07:17 -
video capture problems - HV20 camcorder is controlled but no video capture
By chebowitz in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 14Last Post: 27th Feb 2010, 10:49 -
Problem:Using Video Capture Card for capture or spy another PC.
By gmchn83 in forum Video Streaming DownloadingReplies: 1Last Post: 15th May 2009, 14:56 -
capture advice: USB 2.0 video capture adapter?
By j jasper in forum Capturing and VCRReplies: 10Last Post: 26th Feb 2008, 19:18
