no matter which version of TMPGEnc i use i get the prob of video gettin slightly red and then back to normal... over and over. im using winxp corp final. im trying to convert me myself and irene and this is what happens... i have converted other movies with no prob. any ideas? its just weird... like some kind of protection. hmmm...
thanks for any help
peace,
IgGy![]()
thats what i thought... but i didnt know if this was possible. is there any way to get rid of it?
thanks!
peace,
IgGy
Reason I ask;
If you created DivX from dvd .... when "flasked" ... etc you may be given simple option to remove macrovision. If you d/l this file & the creator of the file left it in place. Aloso you did not mention how severe of a color change it is. check the posts here as i think i read a month or @ 5 WEEKS AGO someone had used a standard tool (tmpgenc) to remove after initial conversion to mpeg1. Don't quote me as to which tool as I did not commit to memory as was looking for something else.
How do you take red (or other color) out of every frame
By deezin in forum Newbie / General discussionsReplies: 10Last Post: 24th Jan 2009, 11:57 -
VHS tape displays red saturation during normal playback only
By mlong30 in forum Capturing and VCRReplies: 2Last Post: 25th Oct 2008, 14:11 -
[color=red]how do you play region 2 dvds on this setup[/color]
By j821977 in forum Newbie / General discussionsReplies: 4Last Post: 3rd Apr 2008, 15:58 -
[color=red]Huge annoying title[/color]
By JohnnyMalaria in forum TestReplies: 1Last Post: 1st Feb 2008, 11:47 -
[color=red]hd again[/color]
By gunukhan in forum DVD & Blu-ray PlayersReplies: 3Last Post: 31st Jul 2007, 14:17
