I'm creating a 2 movie dvd in MF and when creating the dvd image, it stops and states "Some chapter entry numbers exceed the total frames".
Each of the movies have 23 chapters and I even thinned the original number of chapters to that. Does anyone know what I'm doing wrong?
Just curious - how were the chapters created. Automatically or manually? For some reason the program seems to think the chapter begins on a frame that doesn't exist - for instance you have 10000 frames and the chapter is supposed to begin at frame 10002. I'm just guessing on this because I haven't actually run into this problem myself. Are you combining the moveis to make one long movie - or are they two separate videos once the dvd is complete?
3.141592653589793238462643383279502884197169399375 105820974944 -
Well I pin pointed the problem. The file that I created through dvd2one, then demultiplexed/multiplexed into a mpeg file was the problem. I saw on another thread that if it wasn't reencoded with a 3:2 pulldown it will cause this error. I used their solution, the error went away, however now the audio is way off.
As far as chapters, by manually do you mean "every 5 minutes" for example? If so my version of MF2 doesn't have that for some reason. But I do select the option for MF2 to select the closest scene for me.
I hope this was enough added info for someone to help me solve this. -
I am almost pleased to hear that someone else is having this identical problem.
I encoded 2 AVI files to MPEG2 using TMPGENC and MF2 handles these OK with no chapters , but as soon as chpater pints are added - the error message.
Like you its driving me mad, and I can get no help from Ulead, they do not answer the phone or reply to E mails.
Any further thoughts -
I had the same problem with a file that was 23.976 with a 3:2 pulldown and when i re-encoded to leave it at 29.97 the problem went away. This probably isn't what you want to hear but I couldn't find any fix for that bug other than re-encoding the file. These authoring programs are still in their infancy as fas as what they will accept so I chalk it up to that. If you manage to find the solution that doesn't involve re-encoding PLEASE post your method for the next generation
Movie Factory 6+ with HD-DVD Plugin
By wulf109 in forum Blu-ray RippingReplies: 1Last Post: 25th Oct 2010, 12:20 -
Ulead Movie Factory queries
By Mark Wynn in forum Authoring (DVD)Replies: 2Last Post: 11th Apr 2010, 21:42 -
alternative to ulead movie factory
By marlo in forum Newbie / General discussionsReplies: 1Last Post: 15th Sep 2008, 04:48 -
Trouble with movie factory 6 pro Help!!
By blues100 in forum Capturing and VCRReplies: 3Last Post: 16th Oct 2007, 22:44 -
Ulead Movie Factory 6 plus
By ictaylor in forum Newbie / General discussionsReplies: 1Last Post: 10th Jul 2007, 03:20
