  1. I have been burning vcd's for awhile now, and I just now read the tutorial to burn menu's onto vcd's using NERO, the latest version. I followed the tutorial to the t, but after i burned it, I put the vcd into the dvd player of my computer and everything looks great, but I cannot click on the thumbnails to play the videos. I double and triple checked the tutorial, and still can't figure it out. Am I doing something wrong, any suggestions.
    Thanks to anybody who can help.
    Mar 2003
    Las Vegas, NV
    Your particular DVD player may not support menus in VCD mode. Try the same VCD in another DVD player, preferably a new model.
  3. Are you using the arrow keys or the number keys to try and "click" the thumbnails? You should be using the number keys. Sorry if you already know this, but a friend of mine recently made the mistake of thinking that Nero could make a VCD menu with DVD-like interaction (like moving a cursor instead of entering a number).
  4. That was it, I didn't know you couldn't do that. Thanks RowMan
