Hi pros,
Im trying to create my D2V with dvd2avi. I have the vobs on my HD but when I try to process them onto DVD2AVI I can see that the images at start are in two lang. They arenīt subtitles, are images in spanish and english that switch between vob cell id 2 and 3.
For example, the movie's presentation have some frames with "Attack of the clones" and other frames with "El ataque de los clones"
How can I process ONLY one of them ?
thanks
I had a weird problem ripping StuartLittle 2 using DVDDecrypter. It kept jumping between VOB cells , anyway
I switched to Smart Ripper and the VOBs turned out fine.
Try a different ripper to what you are using.
Double-sided, double-layer. Are they the same thing?
By ibzomie in forum MediaReplies: 8Last Post: 5th Feb 2011, 16:13 -
Mariah Carey's version of Auld Lang Syne
By deadrats in forum Off topicReplies: 0Last Post: 2nd Jan 2011, 16:32 -
MPC HC x64 double images/videos since svn 1503? (pix attached)
By tigerb in forum Newbie / General discussionsReplies: 2Last Post: 21st Jan 2010, 07:30 -
How to add .srt subtitle (With Unicode Lang) to a video with TMPGEnc XPress
By 9kamal in forum SubtitleReplies: 1Last Post: 18th Oct 2008, 21:09 -
DVD platback results in double images
By lmcnlcy in forum Newbie / General discussionsReplies: 2Last Post: 1st May 2008, 14:23
