I have my old PIII-450Mhz with a 256M Ram and I installed a FireWire PCI card to download my DV movies. Does this look sufficient? or do I need a more powerfull pc to download and edit my DV?
Capturing shouldn't be a problem ( it depends on the speed of your HD and uses very little CPU ). Now editing and encoding you will have problems cause encoding especially is CPU intensive.
Lacie Cinema: Can't power device on using remote but will power on with USB
By truequant in forum Media Center PC / MediaCentersReplies: 1Last Post: 14th Nov 2011, 04:03 -
phantom power
By birdfeeder in forum Newbie / General discussionsReplies: 6Last Post: 25th Apr 2011, 12:03 -
Building a Low Power Desktop...with Laptop like power?
By Moontrash in forum ComputerReplies: 31Last Post: 18th May 2010, 23:15 -
Power off memory
By Aten in forum DVD & Blu-ray PlayersReplies: 9Last Post: 3rd May 2008, 21:35 -
Does anybody have Power DVD v7.3?
By Sean_ve99 in forum Software PlayingReplies: 7Last Post: 11th Dec 2007, 01:12
