Hi,
Can anyone explain why if I create a DVD in DVD Workshop and then copy this using RecordNow Max the amount of space when you look at the disc is a lot more with the copy than the original. When you look at the amount on the disc in explorer though they are identical.
I presume it is something to do with the lead in and lead out but why should this be different and does this have any bearing on the compatibility with DVD players?
