What is the difference in quality when using a direct stream copy in Vdub as opposed to converting the original avi in TMPGE? I was supposing that there must be a drop in quality since the direct stream copy takes a lot less time to create. I was forced to use a direct stream copy because my video had so many bad frames. I was curious if the difference is at all that noticeable?
Direct Stream Copy is a setting you can use for audio and video in Vdub. As you said, it's used when saving a video file after scanning for bad frames. It tells Vdub not to change the video file but to save it as is. The opposite is full processing mode which allows for filtering, recompressing and several other common functions. Direct Stream does not change the quality at all, unlike full processing mode which can change it (for better or worse). You are doing the correct thing, always remove bad frames!
8)
cut video and save as direct stream copy
By supercain in forum EditingReplies: 47Last Post: 8th Sep 2012, 09:32 -
No direct stream copy in vegas pro 11?
By supercain in forum EditingReplies: 13Last Post: 18th Dec 2011, 02:10 -
direct stream copy of a mkv file Q
By Information in forum EditingReplies: 5Last Post: 20th Jul 2009, 14:06 -
Direct Stream Copy for All Formats
By bigMach™ in forum EditingReplies: 10Last Post: 11th Jun 2008, 13:02 -
Virtualdub direct stream copy takes _forever_. What's going on?
By Colmino in forum Newbie / General discussionsReplies: 3Last Post: 8th May 2008, 08:01
