Hi,
I am new to DVD burning...I am about to get a DVD+R drive. My questions is as follows: With a data CD-R, I can burn a 2nd session and add to the disc. Is such a thing possible with a DVD+R with MPEG-2 video to be played on a standard DVD player connected to my TV?
I would like to be able to burn a 10-minute home video, for example, and then add another one later.
Thanks,
Mike
First part of the question. Can I record multiple sessions on a DVD like a CD. Answer, yes. I do this with data disks all the time.
Second question, can I do this so it will play in a stand alone DVD player.
Answer, I don't believe so, but may be wrong. The problem is that in order for your DVD to play in a standalone, it has to be all packaged up in the DVD standard structure, and there is far more to it than simply adding an additional video file. If you need to do this, I would recommend RW disks.
That said, if you don't use DVD format, but use SVCD if your player is compatible, then you could simply add mpeg file after mpeg file on the DVD disk. I have done this with episodes from TV shows. As I get new ones, I encode them to svcd and then add them to a blank DVD+R.
Rip DVD-R's, edit out commercials, burn new DVD Dual Layer...software?
By ruehl84 in forum Authoring (DVD)Replies: 5Last Post: 23rd Feb 2012, 04:06 -
Incorrect Timing on DVD burn: H.264 mp4->ffmpegx->Toast or Burn
By DirectorSG in forum MacReplies: 2Last Post: 29th Jan 2012, 13:42 -
DVDs burn fine, but Audio CDs only burn 1st half of songs right...
By Xenogear900 in forum Authoring (VCD/SVCD)Replies: 7Last Post: 28th Jan 2010, 05:26 -
Advice required when trying to burn with img burn
By IPBR21054 in forum SVCD2DVD & VOB2MPGReplies: 4Last Post: 1st Aug 2009, 17:29 -
Burn Software with Menu & burn xvid avi
By CynthiaBlue in forum Newbie / General discussionsReplies: 3Last Post: 4th Jul 2007, 21:46
