  1. In the past few weeks I have started buring all my DVD's with RecordNow Max... They have all turned out perfect.. But my problem is when it comes to DVD's that have both Widescreen and Full screen... I open DVDDycripter and rip the movie without the widescreen... ANd when I try to burn it wth RNM I get error's before I start the burn!
    Any ideas???
    And I can see that the the widescreen and full secreen are 2 totaly dif. video sources...
    Yes I am a newbie!!!
    Apr 2003
    Classified
    Try with Nero. The reason it is failing with RNM is the files are missing. U can also use ifoedit and remove the widescreen that way but RNM will still give errors....you can also try going into options and unchecking recognize Video_ts and Audio_ts as per DVD spec.
  3. Originally Posted by jnk76
    I was just going through the options and thinking about trying that!
    And I was wondering how to remove it with IFO Edit? Do I just remove all the VOb ID's for the movie? Or is there a guie somewhere?
    Thanks!
    Edit:
    Im not sure if its the same with all movies, but the mune info (which I like to keep) is on the 1st set of VOB's (VTS_01_00.vob) and the widescreen is on that same set.. So I keep The IFO and BUP and the VTS_01_00... and remove the other movie files..
    Apr 2003
    Classified
    I think all I did was open the ifo file that pointed to the full screen movie I wanted deleted and pressed delete playback which removed the time code for that PGC. I am pretty sure RNM still gives errors though. Burned it with nero and it worked perfect.
  5. Well I burned it with RNM and it works in my computer but not my DVD player
    Do you think if I burn with Nero I would have better outcome?
