I have ripped a dvd using the dvd decrypter and am now trying to convert to divx. When I open the Vob files in virtualdubmod the frame rate is 29.970, and the running time is short by about 15 minutes. I changed the frame rate to 23.976 this corrected the running time. However, once I'd converted to divx the audio was out of sync, at some points it is in sync and others it's not. When I've looked at the framerate in vDub, there is an option to change the frame rate so audio and video durations are the same, the framerate then is something like 23.988. Unfortunately trying this didn't help the problem. The problem only occurs on some NTSC dvds, PAL dvds are fine. Can anyone help, this is causing sleepless nights.![]()
Results 1 to 1 of 1
VirtualDubMod: Audio out of sync
By Ununhexium116 in forum EditingReplies: 4Last Post: 12th Dec 2011, 13:22 -
VOB to AVI (Lagarith lossless) Audio Out of Sync
By Eva-Unit01 in forum Video ConversionReplies: 10Last Post: 17th Aug 2010, 09:50 -
In VirtualDubMod, if the audio is longer to video would it cause sync probs
By breadbin in forum Newbie / General discussionsReplies: 2Last Post: 14th Jul 2009, 06:35 -
VirtualDubMod - Does it keep audio sync?
By vodmare in forum Video ConversionReplies: 4Last Post: 13th May 2008, 01:15 -
VirtualdubMod: DivX and vorbis aduio -- result file has no audio
By cheerful in forum Newbie / General discussionsReplies: 2Last Post: 27th Aug 2007, 01:27
