As most of you know there is more than one manufacture that makes Memorex brand DVD-R. I think I've found out how to distinguish between them without taking them out of the box.
The first and second time I bought Memorex DVD-R were 3 packs in Staples. They were Taiyo Yudens. I've didn't have a problem with any of them burning at 2x and all the way to the edge.
This time I bought a 5 pack from circuit city and DVD Info says they are CMC Magnetics. I don't intend to try these out because of reports in the media section and bad experiences with CMC CD-R.
Anyway, before buying it, look at the back of the box. If it says made in Japan, then its Taiyo Yuden. If it says made in Taiwan, then its CMC. Also the cases are different, the Taiyo came in regular CD cases that have 90 degree edges. The CMC cases are not regular CD cases and have round edges.
Results 1 to 1 of 1
File types and DVD player
By rogmath in forum Newbie / General discussionsReplies: 10Last Post: 7th Jan 2011, 14:24 -
Container Types Compatible with Stand-Alone DVD Players
By Groami Geistalt in forum MacReplies: 5Last Post: 12th Mar 2010, 00:20 -
Putting different types of file formats on to DVD-R
By carl606 in forum Newbie / General discussionsReplies: 10Last Post: 11th Mar 2010, 05:11 -
Which DVD Player For Under $50 Plays Most Downloaded File Types
By DJboutit in forum DVD & Blu-ray PlayersReplies: 10Last Post: 6th Jan 2010, 14:55 -
Best Portable DVD Player For Playing Flie Types
By DJboutit in forum Portable VideoReplies: 2Last Post: 13th Jul 2008, 22:57
