I had posted this question, in the wrong group before, so here is my question.
I was having trouble with the new Version of "VCD Easy" do I uninstalled, then reinstalled my CD-RW (Iomega) now when I try to burn a DVD I get this Message" ERROR: Cannot setup device 2,0,0." can someone please tell me how to fix this problem? Thanks in Advance...
Results 1 to 10 of 10
I had the same problem with my NEC dvd+rw, trouble is now I can't burn to cd or dvd with any software. This all started after I used Force Driver on the setting page (mmc-generic and mmc-generic raw). Ive tried reinstalling the programs, checking the ASPI drivers, used force drive to revert to ASPI 4.60 but nothing seem to work. Ive checked the drive using device manager and it shows the drive working properly. This is driving me nuts! Pleas help!
I got my NEC DVD+RW working again, first I uninstalled the drive, then I uninstalle Roxio Easy CD creator. Restarted my computer, at which point XP installed the drivers. Then I reinstalled Easy CD Creator and went to
http://www.roxio.com/en/support/software_updates.jhtml and downloaded the latest version of Creator. This worked for me, and I got the information from http://the-predator.tripod.com/. Hope this helps you.
PanHead
Unistall your cd drive, then reinstall it if the install wizard doesn't start. When it asks put the software disk in that came with your cd drive. This should get you fresh drivers. I don't know if it matters but I have Easy CD Creator on my computer and I had to install the latest version (why that mattered I don't Know). I also uninstalled my cd copy software and reinstalled it. I guess I was shot gunning to get it fixed. All I know is it works and I've burned 4 DVD's since.
has any one had trouble installing roxio easy vhs to dvd 3
By dirtfarmer in forum Capturing and VCRReplies: 0Last Post: 30th Apr 2012, 23:04 -
Trouble Editing/Trouble Base Media?
By SlickPen in forum EditingReplies: 0Last Post: 20th Mar 2011, 19:53 -
Hardsubs Easy
By kazz0817 in forum SubtitleReplies: 1Last Post: 22nd Jan 2011, 04:44 -
Is there any easy way
By kemcel in forum MediaReplies: 1Last Post: 17th Mar 2009, 08:07 -
VCD Easy
By kshavo in forum Authoring (VCD/SVCD)Replies: 10Last Post: 12th Feb 2008, 14:43
