Hello.
I just found out that my APEX AD-600A does not play DVD-Rs. (I do not want to open the case to find out which drive it has, plus, if the drive firmware upgrade doesn't work, it would ruin the player.) I've heard good things about the Sampo DVE-612. Does it play DVD-Rs out of the box? Or will I have to do things like open the case and preform unsupported upgrades to make it do this?
Thank you.
Read my journal! http://slashdot.org/~dmarx/journal/
Are you referring to the Sampo 612(N)?
yes, it plays most discs, no rw's though i used,
the key to this player is....
It WILL play data files, like mpegs without
converting to vcd or anything like that,on dvd-r's,
also plays jpg's on cdr's...
Only $60 or so....
Customizing 'Test" DVD's: HQV Benchmark, DVE & Avia
By videobruce in forum Authoring (DVD)Replies: 4Last Post: 28th Sep 2010, 13:24 -
dve hd basics blu-ray disc
By romanticwarrior in forum DVB / IPTVReplies: 1Last Post: 9th Mar 2009, 03:38
