I got a copy of DVD2one from a friend and I am trying to burn with nero. I ran DVD2one and got a few VTS_01_* files, where the * is 1-5, a VIDEO_TS.BUP, VIDEO_TS.IFO,VTS_01_0.BUP and VTS_01_0.IFO. I also got a file titled default which is the same as the VTS_01_5 file
My problem is I don't know where to put them in nero.
"My first computer cost $2,400, had no hard drive, 16K of memory, a 120KB 5" floppy disk, [and] a green monitor"
Gritz-dvdrhelp.com -
Click on New Compilation in Nero, then you should see a template for DVD VIDEO, click to enter that, it should show 2 folders labeled AUDIO TS and VIDEO TS. Put the files made from DVD2One in the VIDEO TS folder and burn away.
If you don't see a DVD Video template, make sure you 1) have a DVD burner installed, 2) Upgrade to the newest version of Nero, 3) In New Compilation, make sure it has DVD templates selected and not CD templates. -
Should I put all the files in including the default file? Does the order matter with the BUP and IFO files? If so where should I put them? Thanks
Which version of Nero are you running? Nero Burning ROM or Nero Express. Both will work but the directions are a little different. Let me know. Its real easy. Always include all the information in your post. It makes getting an answer quicker and correct the first time.
I am using the latest version of Nero Burning ROM.
There is no actual "Default" file. Although the VIDEO_TS folder icon is red instead of yellow. Put the contents made by DVD2One into the VIDEO_TS folder and Nero does the rest as far as rearranging them to be compliant with the DVD disc structure.
How to PROPERLY burn DVD2ONE DVD's using TOAST 6.0
By galactica in forum MacReplies: 170Last Post: 30th Mar 2012, 03:48 -
Nero will burn 4X, DVD Shrink-Nero only 2.5X
By happydog500 in forum DVD RippingReplies: 16Last Post: 4th Jan 2010, 20:49 -
Can't burn video TS with nero
By anfield7 in forum Newbie / General discussionsReplies: 3Last Post: 2nd Dec 2008, 03:19 -
HELP Burn using Nero Express doent work /but NERO VISION work fine
By STAR36 in forum Authoring (DVD)Replies: 4Last Post: 28th Apr 2008, 17:11 -
NO sound when i try to burn in nero 7..
By lil_jayz76 in forum AudioReplies: 3Last Post: 3rd Nov 2007, 21:05
