  1. I'm working on a slideshow with tmpgenc and having some difficulty. I have several jpgs, and a wav to go with each. I go into tmpgenc and select the jpg as my video source and the corresponding wav as my audio. My jpgs are named ...1.jpg, ...2.jpg and tmpg automatically includes each jpeg into the mpg I am trying to create. So, pic1.jpg and pic1.wav automatically includes all of the pics in the directory (even though I only want pic1.jpg). It works fine if there is only one jpg and wav in the directory. Is there a way I can tell tmpgenc to not include the extra jpgs in the final mpg? Thanks!
    Central IL
    Don't use numbers to end your .jpg file names... TMPGEnc is using all the pictures in your directory because it thinks you have individual frames in each file that you want to use one right after the other...
    So instead of using pic1.jpg, pic2.jpg, pic3.jpg, etc... for filenames try using pic-1a.jpg, pic-2a.jpg, pic-3a.jpg, etc... instead...
    CogoSWSDS
  3. ahhh... tricky tmpgenc... I'll give that one a shot Thanks!
