I have finaly understood that most capture cards are being used mainly for enhancing the PQ or changing the aspect ratio of their video.
I only want the card for recording/playback purposes only. My PQ is fine the way it is now. I want it to be similiar to a VCR.
So the question is which capture card is the best for recording a show for a later playback?
Try going to capture cards section and search for TV tuner cards. Sould be what you want.
I actually do not need a tuner. I will input the signal via s-video from my satellite receiver.
I am thinking of the Creative Digital VCR, but the reviews are mixed. -
I use the Creative Labs Digital VCR and it works well for me. I took my sons 7 Rescue Hero VHS Videos (Each 11 min in length) and captured with this card. I converted the videos to MPEG-2 with the conversion program provided with the card. I used virtualDub - MPEG to convert to an AVI file for easy use in Studio 8.5.21. Created a menu for them and burned to DVD.
I have not used it to record a show from my satellite dish (that is what I have it hooked up to currently) and play back. My best guess is without having to go through similar step as I mentioned above, you would only be able to watch the recorded program on the computer. The card does not have a video out.
It does a great job of recording though. I recommend the card. I cannot speak about any other cards...
Need help buying a Capture card for xbox match recording
By Raw_Habitz in forum Capturing and VCRReplies: 23Last Post: 9th Apr 2011, 18:08 -
Pinnacle Transfer Capture card not recording footage of my N64?
By chibirobo1 in forum Video Streaming DownloadingReplies: 6Last Post: 28th Mar 2011, 22:03 -
This Capture Card for Xbox 360 Recording
By Evansslaught in forum Capturing and VCRReplies: 8Last Post: 19th Jan 2010, 14:50 -
recording cable HD channels on pc tuner/capture card
By Zipbiscuit in forum DVB / IPTVReplies: 2Last Post: 26th Dec 2009, 10:52 -
Suggestion on Laptops for sound recording purposes (vocals, keyboard o/p)
By tsrusa2002 in forum AudioReplies: 4Last Post: 18th Mar 2008, 22:27
