How do i rip to AVI i am using
1. Smartripper
2. DVD2AVI
3. DVDx
4. Nero
What am i not doing correctly,
What i want to do is be able to peek & Tweat my audio & video files befor, I like the features of vitualdub but have not been able to understand how to get to and AVI using the programs above. I have checked forum and i see nothing abt converting to and AVI did i overlook something...........Thanks
Pachuta, Ms.
Here's the guide, pretty good too.
https://www.videohelp.com/sefy/
Or have I read your post wrong
Well i guess i id not clearly explain what i would like to do.
I would like to backup my Classic,s To and AVI format.
I was using DVD2AVI & DVDX which works fine but end result is a D2V extension, but some of my older dvd's i need to adjust audio & video, and for that i would like to use Tmgpenc & vutualdub.
ThanksPachuta, Ms. -
Get the VFAPI converter. It will convert the .d2v file into a fake .avi file. After that, you can load it into some encoder (I use Nandub).
Here's a link http://www.divx-digest.com/software/vfapi.html
help me how to make a set of avi files to DVD with menus of each avi file
By mmah in forum Video ConversionReplies: 5Last Post: 9th Mar 2011, 02:07 -
Found DVD/AVI software player that displays Chinese srt subtitles with avi
By jimdagys in forum Software PlayingReplies: 1Last Post: 14th Nov 2009, 19:45 -
Create Root menu for avi's on DVD without converting each avi?
By Ghtpua in forum Authoring (DVD)Replies: 2Last Post: 7th Sep 2007, 23:23 -
I have converted avi to vcd and svcd im looking to convert avi to dvd
By dbztoolkit in forum Newbie / General discussionsReplies: 1Last Post: 11th Jun 2007, 12:14
