Mpeg2 file demuxed through tmpegnc. Left with 2 files.
M2V=Video
Mp2=Sound
M2V through CCE leaves an MPV video file.
Now, Pulldown is looking for an M2V File not an MPV so, should I run it before CCE or rename the file *.M2V and run it through pulldown after?
This Mpeg2 file was captured NTSC.
Don't give in to DVD2ONE, that leads to the dark side.
Right in the middle of doing just that.
umm. there are a lot of option.
DVD2DVDR uses this pulldown and they come out fine. So, in a perfect world I should not have a need to change any of the option when I run the program myself.
I guess I'll find out soon.
ThanksDon't give in to DVD2ONE, that leads to the dark side. -
Using just its default settings, pulldown will add the 3:2 pulldown flags and do nothing else. For most cases, this is all you need to do when backing up an NTSC DVD so the default settings should be fine, unless you have a particular reason to change them ie: change field order, change aspect ratio, set frames to progressive etc..
As it turns out the time stamp in CCE was not set to Zero. So I rechecked the files that I had right after encoding. Both the video & sound had the same time. Remuxed them in Tmpegnc. The mpeg doesn't seem to play right in WMP. I think I'll burn it to a disk and check it on the standalone.
Let's see where I'm at.
Audio file is 1.42.27 (total Time)
Video file is 1.42.27 (total Time) after CCE
Muxed file is 1.42.27 (total Time) after Tmpgenc
Plays fine in Windows.
Audio lags behind video when played on stand alone. Tried 2 different burning software.
The Min bit rate for CCE is set to 300. I think I read here that, too low of a bit rate makes it hard for the player to decode the file.
Any thoughts?Don't give in to DVD2ONE, that leads to the dark side.
Pulldown? when Encoding a 29.970fps progressive AVI to NTSC DVD
By FulciLives in forum DVD RippingReplies: 5Last Post: 27th Feb 2012, 20:00 -
2:4 Pulldown
By supervehicle in forum Video ConversionReplies: 23Last Post: 3rd May 2011, 17:53 -
CCE Encoding timecode error and pulldown
By dannybz in forum Authoring (DVD)Replies: 22Last Post: 16th Aug 2009, 11:45 -
3:2 pulldown?
By blizzery in forum Video ConversionReplies: 3Last Post: 24th Jul 2007, 07:38 -
Using pulldown
By MysticE in forum Video ConversionReplies: 2Last Post: 14th Jul 2007, 04:25
