I have the latest revision of Roxio Platinum 5 on my computer. I'm considering installing Nero as it seems to be the software of choice for burning DVDs. I have tried buring VIDEO_TS folders with Roxio as DVD data files but they don't play on my standalone. Am I going to have problems if I keep my Roxio? I am more comfortable with Roxio as I have never worked with Nero before.
@falberni,
I have both installed and use both without any problems. I also have installed VCDEasy and Click N Burn. No problems with any interactions. -
Only 1 way to find out m8 8)
I have roxio, nero, nti cdmaker, cdr win...
All installed in the same system no problem here.
(Damn i love Windows XP) -
The most common conflicts are between packet writing software - Roxio's DirectCD and Nero's InCD. If you avoid installing both of these (or better yet, EITHER), you shouldn't run into problems.
Also, make sure to disable Roxio's Project Manager from your System Tray so it's not auto-running on you.
Then if you're manually activating the programs you're cool.~~~Spidey~~~
"Gonna find my time in Heaven, cause I did my time in Hell........I wasn't looking too good, but I was feeling real well......" - The Man - Keef Riffards -
At nero.com they have a patch specifically for that, it in the d/l section.
SeanWe all like Sheep have gone astray...
Can Roxio USB capture be used without Roxio's software?
By miamicanes in forum Capturing and VCRReplies: 4Last Post: 18th Oct 2012, 16:30 -
Best software for Video Editing - Nero, Roxio or Pinnacle Studio
By bpatters69 in forum Newbie / General discussionsReplies: 27Last Post: 28th Dec 2007, 22:11 -
How do I get Roxio Easy Media Creator to Do What I Used to Do With Nero?
By AlleyCatty in forum Authoring (DVD)Replies: 0Last Post: 20th Nov 2007, 15:27 -
Roxio vs Nero
By gthorley in forum Authoring (DVD)Replies: 25Last Post: 23rd Aug 2007, 02:08 -
Nero and Roxio Questions
By Big C in forum DVD RippingReplies: 7Last Post: 28th Jul 2007, 20:39
