Hi
I have some small VOB files in DVD quality, without IFO files. I can easily play the files from Cyberlinks PowerDVD XP, but now I would like to burn these VOB files into a CD-R, so I could look at them from my normal DVD player (Philips DVD 751). Is it possible to burn them in that UDF format as on normal DVDs ?, so this CD-R would function like a "mini-DVD".
It would be nice if it could be avoided to make a convertion to SVCD, because then I loose quality, but if this is the only way, please describe how I can do this.
Can anyone help me ?
Most DVD Players do NOT support minidvd/cdvd.
www.dvdrhelp.com/minidvd
www.dvdrhelp.com/dvdplayers.php?DVDname=&minidvd=1&Search=Search&Submit2=Search -
Thanks,
I have now followed the guides, and made a folder on C:\VIDEO_TS, copied the VOB files down there, and then rename them to VTS_01_x.VOB, run IFOedit to create the IFO and BUP files. Burned it with Nero on a CD-R.
It would not play on my Philips DVD player, but it worked on my cheap United DVD player.
Thanks again Baldrick
Combining Mini-DVDs into 1 DVD
By Jinga in forum Newbie / General discussionsReplies: 4Last Post: 17th Sep 2010, 12:06 -
What program to use? Compile 4 mini dvds into one
By ulremember in forum Authoring (VCD/SVCD)Replies: 2Last Post: 25th May 2010, 16:55 -
Converting mini DVDs to be able to edit?
By twells22 in forum Newbie / General discussionsReplies: 1Last Post: 12th Nov 2007, 05:37 -
simple compiling of multiple mini-DVDs
By tepeco in forum Authoring (DVD)Replies: 3Last Post: 5th Aug 2007, 18:46 -
why cant i play the mini dvds that i copied on to my P.C's hardrive?
By boomblaszy in forum DVD & Blu-ray WritersReplies: 4Last Post: 21st Jul 2007, 12:22
