I have 2 AC3 files, and want to make 1 of it.
How do i put 2 AC3 files to 1 AC3 file ??
I'm using DVD Maestro.
Let me explain how i worked :
I have a DVD-rip of Face-Off.
The movie is on a double-sided DVD-disc.
So i ripped the MPG-stream of Side 1 to a M2V file.
The AC3-stream of side 1 i also ripped to 1 AC3 file.
I also ripped both streams of Side 2, so i have the following files :
faceoff_video1.m2v
faceoff_video2.m2v
faceoff_audio1.ac3
faceoff_audio2.ac3
The m2v files are no problem in DVD-Maestro, i put the begin of video2 to the end of video1....no problem.
I can add the audio1.ac3 stream into the audio-track, but audio2 can't be added after the audio1 stream.
When i try this it says :
"Track already contains an asset. Replace it ??"
Or should i convert the AC3 streams to MP2 and then use CoolEdit to make 1 mp2 file ?? -
Try Vobmerge.
I think it can join individual ac3 files as well as vob files.
http://www.angelfire.com/nc/evilmastr/vobmain.html -
DVDMaestro -> Perfect -> This is what you do:
Take your 2 .m2v's and add them to the movie timeline. Don't drag your .ac3 files but make sure they are part of the assets. Now right click in the audio track 1 area of the movie timeline and select the option for Create Sync Audio Track. DVDMaestro will bring up some options and you can create 1 .ac3 file of multiple .ac3 files.
After it creates the 1 .ac3 file, import it to your assets and drag that onto the movie timeline for audio track 1.
For the chapters, if you have a .chp file you can import it for only 1 of the video streams. For the other half of the movie, you will have to manually enter the chapters
This works like a charm for putting flippers onto 1 DVD-R.
Good Luck.
dpcpro
How to create M4V files w/AC3+AAC from M4V w/AC3 only??
By williamlondon in forum MacReplies: 4Last Post: 5th Oct 2010, 16:15 -
Joining MPEG2 files with different AC3 audio delay on each file
By Killer3737 in forum EditingReplies: 6Last Post: 27th Oct 2008, 23:32 -
How to convert AVI/DivX/XviD with AC3 to DVD with AC3
By Baldrick in forum User guidesReplies: 52Last Post: 21st May 2008, 19:22 -
Sync issues after converting AVI (DivX 5/AC3) to MPEG2/AC3
By Greycat in forum Video ConversionReplies: 4Last Post: 25th Mar 2008, 10:24 -
H264 + AC3 + AC3 --> VOB - What is wrong with my command line?
By olik in forum ffmpegX general discussionReplies: 5Last Post: 3rd Feb 2008, 07:06
