    Apr 2003
    Europe
    When trying to replace audio track the project goes to 4.7 GB, which is an oversized DVD and there's no way to burn it.
    Anyone else had this problem or is it just me?
    I almost go mad.
    Change to mp2 audio or lower the video bitrate? under project settings->change mpeg settings.
    Washington, D.C.
    @Baldrick,
    I too have ULMF2 but your suggested change is not possible. My MPEG optins are grayed out.
    Apr 2003
    Europe
    Tried everything and the result is the same.
    Bug.
    Apr 2003
    Europe
    The bug is in my head!
    After so many hours at the screen I didn't realize that after replacing the audio tracks the bitrate changes automatically to 8000 k/s.
    Newbie things I guess, you'll have to forgive me, I got nervous.
    Apr 2003
    Europe
    Definitely there IS a bug in the program!
    Tried with a 65 min movie and even putting the settings at Half-D1 (352x576 & 2400 kb/s max) and if I replace the audio track it results an unrecordable 4.7 GB disc.
    How could I report Ulead about this?
    Washington, D.C.
    kantazo,
    you can go to www.ulead.com and then contact us. fill out the email form then sit back and wait. They do eventually get around to answering you but it will take several days or at least it has so far.
  8. Member marvel2020's Avatar
    Mar 2001
    Vorlon Home World
    Fat lot of use that is going to the Ulead site and filling in that form.
    You have to buy the product first then use your registration info to get a responce.
    They won't answer any thing to with the trial version, but they suggest you use th FAQ's to see if that helps.
    Well in my case it doesn't, all i want to know why UMF2 will not overburn, but UMF will.
    All i use them for is VCD's.
    I Have Always Been Here
    Toshiba Regza 37Z3030D, Toshiba HD XE1 + EP-10 ( Both Multiregioned), Samsung BD-P1500 Blu Ray. OPPO DV-983H
