I am in Australia (PAL) and have a digital Video Cam and I want to capture film and use Stuido 8 to capture and make it into a SVCD and send it to a mate int he USA (NTSC)... now when I make a SVCD should I capture in NTSC even tho the original film is PAL or do I capture it in PAL and then edit it with TMPGENC which I will have to read up on... then burning it with Nero I think there is a PAL/NTSC section in there as well (dont hold me to that)...
Any help would be great
Dave
Your Digital Video camera will be PAL or NTSC (most likeley PAL). You don't 'capture' from a DV cam in the traditional sense, you transfer the data via firewire to your PC and the 'capture' software will warp it in an avi file format. This is where you do your editing, saving your edited footage once again as DV AVI.
Once you have your final footage in an avi file, you can encode to mpeg and change the framerate and standard to NTSC in a few easy steps. There are guides on doing this in the convert section.
Hope this helps
when Pal dvd has correct Ntsc audio (Pal>Ntsc conver)
By spiritgumm in forum Video ConversionReplies: 15Last Post: 13th Oct 2011, 12:57 -
Does making a dvd player region free also allow PAL to display on NTSC?
By dizmack in forum Newbie / General discussionsReplies: 20Last Post: 25th May 2010, 19:50 -
PAL to NTSC, NTSC to PAL framerate conversion?
By Baldrick in forum Video ConversionReplies: 44Last Post: 5th Dec 2009, 23:31 -
NTSC to PAL, PAL to NTSC framerate conversion?
By Baldrick in forum Video ConversionReplies: 23Last Post: 23rd Apr 2008, 11:19 -
Help with PAL SVCD to NTSC SVCD
By silentmonolith in forum Newbie / General discussionsReplies: 4Last Post: 6th Jul 2007, 06:18
