I've been trying to burn a decent quality vcd since I got this thing. I've downloaded a few avi (divx) files and used TMPGenca to convert them into mpg. The source I believe is 1:1 VGA Non-interlaced (is there anyway to find exactly what the source was in if I wasn't the author?), and I've been using the NTSC template...that is 352x240, 1150 b/s and I used the highest quality encode (slowest). I still seem to be getting some blocks and pixellation on the dvd player (seems to play fine on my computer though?!?) It seems my dvd player is really trying hard to read the disc through while watching (I hear the mechanism a lot)....well, is there any good settings or anything else to change in order to get rid of this blockiness and pixellation? I've been using the digital media cdr's and cdrw's from circuit city. Has anyone else solved this problem with the Sony DVP- S560D?
I have the same model sony. From what I have gathered it sounds like you are downloading movies that were poor quality from the start. I am mainly into dvd rips, I use the provided vcd template and convert high quality with the noise reduction filter. the noise reduction will take alot longer to encode but ive found it to be worth it. Also if you are using the Prinko disks from comp usa or circuit city I have found them to be poor media and your dvd player always sounds like its killing itself. The only disks that I have found to work 100% all the time are the Memorex CD-rw
Platinum.
Majinbu
Sony Vegas - Picture-in-picture video creation
By jeanpave in forum EditingReplies: 5Last Post: 14th Dec 2011, 00:01 -
Sony EVO-9650P flickering picture
By AVF in forum RestorationReplies: 0Last Post: 28th Jan 2011, 17:41 -
[Sony Vegas 9] Problem with Picture-in-Picture (Track Motion)
By BramJ in forum EditingReplies: 1Last Post: 27th Jan 2010, 05:52 -
Sony KP-57XBR10W Powers On But No Picture....HELP!!!
By hueyt in forum Newbie / General discussionsReplies: 1Last Post: 25th Dec 2008, 10:16 -
Sony BDP-S350 only gives B/W picture
By masquerain in forum Newbie / General discussionsReplies: 2Last Post: 4th Nov 2008, 16:58
