hello, does anyone have any info on how to rip the picture from the gallery on a foo fighters dvd?
i have used smart ripper and then converted all the video to avi, but i cant seem to find the images which i can easily view with my standalone, is there a way to extract them maybe in bmp or something?
I'm not sure what you are asking but I think you want to just pull one picture [frame] out of a DVD. You can run the DVD in Power DVD or most other newer software DVD Players and just pause where you want the picture then choose Capture Frame save as a .bmp and do what you want with the image. If I misunderstand your question please disregard.
Good Luck
Dd(;-{> Dd
Strength and Honor
www.dvd9to5.com
www.dvd9to5.com/forum/
"For every moment of truth there's confusion in life"
Black Sabbath/Ronnie James Dio -
Open the DVD in DVD Decryptor in IFO mode. Get all the different streams that are not the main one. The ones that are maybe only a few mins long. Or even seconds long. then open that in VirtualDub. Each frame of the stream should be a diffent picture. Then use the copy source frame.
Well I'm not familiar with this DVD but most DVDs store the pictures and menu's in the first vob in the series in which the movie is located. So if the movie is VTS_1.1, 1.2, 1.3, etc... then the menu's should be located in VTS_1.0.
Rip this vob in file mode and then load it into TMPGenc. You can then click on setting and go to the source range filter on the advanced tab to highlight the pictures you want. Drag the slider to the 1st picture and hit set start frame, then drag it to the last picture and hit set end frame. Keep hitting ok til you return to the main screen. Hit file/output to file/sequence BMP/PPM/TGA/JPG file. Set a target dir and filename and set the type of output you want, ie: jpg, bmp, etc... Hit ok and it will create one pic for each frame.
For a guide on how to do this, including an alternate method using virtualdub, you can check out steps 1 and 2 on my guide. http://home.att.net/~adam.poole/Introduction.htm
Help me (How to flash pictures)
By freddiejos in forum EditingReplies: 4Last Post: 3rd Aug 2011, 12:02 -
Resizing pictures
By jyeh74 in forum Newbie / General discussionsReplies: 4Last Post: 3rd Jul 2011, 01:49 -
Beauty&Beast Blu-Ray Ripping Loses 3-Dimensionality after ripping
By KostaRae in forum Blu-ray RippingReplies: 4Last Post: 22nd Mar 2011, 04:50 -
Re : Emailing pictures
By chief-1 in forum Newbie / General discussionsReplies: 2Last Post: 4th Oct 2010, 01:56 -
Pictures?
By taker36904 in forum Newbie / General discussionsReplies: 7Last Post: 31st Jan 2008, 07:45
