when using tmpge to convert to svcd whats the difference in using ntsc and ntsc film?
The NTSC template encodes at 29.97fps.
The ntscfilm template encodes at 23.976fps and includes a flag in the stream which instructs the dvd player to convert your movie to 29.976fps as it plays. This is much more efficient than encoding at 29.97fps because you have ~20% less frames to encode so at the same bitrate, your quality is much better.
So basically, if your source is 23.976fps always use the ntscfilm template and if it is 29.97fps then you can safely use the NTSC template.
The vast majority of commerical NTSC dvds are actually encoded in ntscfilm and use a similar flag to instruct the dvd player to convert it to 29.97fps. So what you need to do is use dvd2avi and enable forced film when making your d2v file. This will preserve the 23.976fps source, and you can then use the ntscfilm template in TMPGenc. This is the preferred way to make NTSC SVCDs from an NTSC DVD source. If your not using a DVD as source, well then just go by what the fps is of your source.
Using NTSC (16:9) and PAL (4:3) sources to restore a film...
By takearushfan in forum RestorationReplies: 61Last Post: 3rd Mar 2012, 16:13 -
NTSC/PAL but exact film length: How so?
By Anonymous5394 in forum Newbie / General discussionsReplies: 2Last Post: 5th Mar 2010, 12:42 -
NTSC video with a film-like/PAL to NTSC conversion type of look that shouldn't
By Bix in forum RestorationReplies: 34Last Post: 8th Feb 2010, 16:17 -
Question regarding NTSC Film DVD
By txporter in forum Video ConversionReplies: 14Last Post: 30th Nov 2009, 10:29 -
FPS NTSC & PAL Film/Digital
By flamingo in forum Newbie / General discussionsReplies: 5Last Post: 13th Nov 2007, 14:21
