  1. Okay,
    I'm fairly computer literate, but I can't figure this problem out...
    I load Nero 5.5.9.9 and I don't have an option to burn a dvd. I can burn them fine w/ Ulead DVD workshop, but not with Nero and I really need to burn a file using nero. My burner is an external Sony DRU-500
    thanks
    cal
    ChitownTaper@attbi.com
    (if you could email me responses i'd greatly appreciate it!)
  2. what do you mean you can't burn with nero? you can't select the dvd portion in the wizard?
  3. You need to upgrade your Nero to at least 5.5.9.17(.0) this is what I use. Or try latest version update from www.nero.com . If you have problem with "how to" try guide that is on this site (I believe). Go to section "How to" on the left.
    Mar 2003
    north dakota
    I had the same problem when I bought my sony dvd burner. You just need to ensure you have the lastest nero edition. The dvd option is less than a year old.
