dloaded sweet flick i really want to watch on the tube and copy for pals. i try to convert with tmpgenc and every time it says it has encountered a problem and must close at the very end! right when it goes to start to encode it seems as though its gonna start then it gives me the win xp message saying it encountered a prob.
i identified the file as a ms mpeg4 v-3 mpeg layer 3 it says in the identifier.
anyone know what the heck? ive tried saving it in moviemaker as a different file type and after 3 hours it locked up!! please help!
Open the file with GSpot (find it in the TOOLS section). It will tell you if you have the necessary codecs installed to properly decode/re-encode the avi.
Start there. If the problem persists, you may need to change your TMPGenc settings. You should also know that most encoders are very sensitive to things like an overly aggressive bios configuration (need for speed...). Overclocking will net you alot of crashes with encoders.Impossible to see the future is. The Dark Side clouds everything...
converting bad laser Sony DVD players into Test Pattern Signal Generators?
By turnkit in forum DVD & Blu-ray PlayersReplies: 5Last Post: 10th Jan 2012, 02:46 -
No video and bad audio when converting AVI to DVD (ffmpegX)
By leosmith in forum ffmpegX general discussionReplies: 2Last Post: 29th Mar 2010, 14:06 -
No Audio In Encore/Bad Aspect Ratio/Bad Files/Bad ISO/Bad Everything
By koberulz in forum Newbie / General discussionsReplies: 35Last Post: 24th Jan 2010, 04:48 -
Problem converting audio of VCD MPEG-1 to author DVDs
By Greycat in forum Video ConversionReplies: 6Last Post: 16th Jan 2008, 16:28 -
This is a minefield! (converting mpeg to mpeg for DVD)
By uth in forum LinuxReplies: 29Last Post: 18th Nov 2007, 15:04
